YS 110 loading up in air
Due to the undersight of the Thundertiger Team when building the Rare Bear, I've only logged 4 flights with my 110, but I'm still having troubles with it.
Last flight out I used a MA 14x7 three blade, with Byron 20/20 YS fuel. The motor ran perfect on the ground taching about 9800rpm, but once I get it in the air it slowly loads up and dies. The plane weighs about 11lbs dry, and once I get her legs stuffed back under her, I'd like to try again.
thanks,
DT
