YS 110 loading up in air
Due to the undersight of the Thundertiger Team when building the Rare Bear, I've only logged 4 flights with my 110, but I'm still having troubles with it.
Last flight out I used a MA 14x7 three blade, with Byron 20/20 YS fuel. The motor ran perfect on the ground taching about 9800rpm, but once I get it in the air it slowly loads up and dies. The plane weighs about 11lbs dry, and once I get her legs stuffed back under her, I'd like to try again.
thanks,
DT
thanks,
DT
The needle is just slightly more than 1 1/2 turns out. But it ran great on the ground with no loading, and it's beginning to idle real nice and also has a good transition after 1 gallon of fuel.
thanks.
thanks.
Honestly, I probably wouldn't know the difference. I just know it runs like a bat outta hell on the ground, but slowly sounds like it loads up in the air - takes a few minutes.
Once i get my gear fixed so I can make a few passes, land, adjust, and go again, I'll have a better chance at solving the problem. I just thought there might be something obvious I was doing wrong.
DT
DT
