RCU Forums - View Single Post - NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Old 04-18-2005 | 01:21 AM
nemesis4u's Avatar
nemesis4u
My Feedback: (77)
Default RE: NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Last update for the nite...it is 1 am and I need some ZZZZZZZZZZZZZ's[:-][:-][:-][8D]
First picture you have the lighting harness for the rear and front lights on the Sherman..Nice and bright [8D] These wires are run inside the upper hull ...
Next, I gathered the parts for the machine gun and the LED that goes with it...Nice metal aircooled machine gun assembly...I Assembled and installed it in the Upper Hull..Note the small black wires and clear bulb poking out of the Hull..That is where one of the Headlamps will be...There are 2 operational headlamps and 2 operational brake/tail lamps...One may turn them on and off from your 4 channel transmitter...really cool effects...I have this on my Tamiya Pershing and makes driving the tank in dark/dim areas lots of fun...
More to come...Hang on.....
ID:	259618   Click image for larger version
ID:	259619   Click image for larger version
ID:	259620   Click image for larger version
