RE: Engine starting
hi maxi you can start the engine by hand but only if you use a chicken stick .get a stick about 12 inches long and cover one end in rubber i used a peice of dowel with hose pipe over the end the rubber protects the prop.but an electric starter would be much easier!!.only give the engine one second bursts with starter though!!.as for the engine yes it would be perfect in your suggested alternative trainers good luck.
