RCU Forums - View Single Post - Futaba 9ZWC2 programming issue...
Old 04-18-2005 | 08:17 AM
Yann
Default RE: Futaba 9ZWC2 programming issue...
OK, Let's take an exemple.
Say you use F->E to compensate for trim changes when flaps are deployed.
You also choose RD dial as Trim Volume Setting to fine tune in flight the amount a compensation you need.
The question is, how do you set the persentage of compensation for one step of the dial.
By default, the range of adjustment is less than 10%. How do you change this ?
Yann
