Futaba 9ZWC2 programming issue...
On the Futaba 9ZWC2 TX, how do you guys change the sensitivity / steping of dials (LD or RD)
when used as volume dials.
Yann
Yann
CO
Yann propably the wrong forum to get a quick ansewer... try ..........this one:
http://www.rcuniverse.com/forum/Futa...mid_125/tt.htm
Lee
Lee
OK, Let's take an exemple.
Say you use F->E to compensate for trim changes when flaps are deployed.
You also choose RD dial as Trim Volume Setting to fine tune in flight the amount a compensation you need.
The question is, how do you set the persentage of compensation for one step of the dial.
By default, the range of adjustment is less than 10%. How do you change this ?
Yann
Yann
