RCU Forums - View Single Post - Putting balance weights on the tail
Old 04-18-2005 | 10:17 AM
Skynyrd Man's Avatar
Skynyrd Man
Default RE: Putting balance weights on the tail
ORIGINAL: bruce88123
Did it fly?
Got the engine broke in and running smoothly at idle and full speed. You guys are right, it can be a pain doing this if you have never done it before.[&o]
Sure hope I don't have the same problem balancing the Rapture with the Evolution.
I will be taking the Tower up in a little bit, hour or two. I will let you know how it goes.
I just want to give it a quick charge and check it over again real good. See if anything has vibrated loose and such.
