RCU Forums - View Single Post - NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Old 04-18-2005 | 10:05 PM
nemesis4u's Avatar
nemesis4u
My Feedback: (77)
Default RE: NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Next inside the turret we add the Receiver base and wiring for the Battle UNIT as well as the main gun elevation base with the metal elevation arm...note the neatly bundled wiring for the Battle Unit.. Then I add the mantlet and 105mm Howitzer....Be careful when gluing that it does not become glued in one position...use glue carefully!!!!!
Note how quickly the Turret will become packed with gear in the next set of pictures...
ID:	259945   Click image for larger version
ID:	259946   Click image for larger version
ID:	259947   Click image for larger version
