RE: runaway twice! two different radios. help please
same prob but mine is totalled. if you think about it the throttle return spring wont do anything cause if you are using it then the servo is not affected buy it unless it is off. but if the throttle was open then that must be because the servo is doing that. hope you understand what i mean
