RE: Firewall and blind nuts...
You can cut out a balsa or thin ply 'washer' with the center hole just big enough for the screw to pass through and the outside diameter somewhat larger than the blind nut. After you ca the nut where you want it, glue the 'washer' over it and the wood around it. Jim
