RCU Forums - View Single Post - Stop from bottoming out?
Old 04-21-2005 | 05:59 AM
scrapheep
Default RE: Stop from bottoming out?
What OFNA shocks? fluid? springs? Try heavier shock fluid for starters, maybe stiffer springs if the problem persists. Remember...its ok for the suspension to bottom off the big hits, if it doesnt bottom out your not using all your suspension travel.
The preload spacers are used to set ride height... they do not increase the spring rate.
