RE: 3d For this setup
G,day Rich.i have one of the E-flite Yaks with the same setup as you except for the motor.(Im using a Himax outrunner).Your setup would work great in one of the E-flite Yaks.These planes fly great with only a slight bit of Knife edge coupling(about 4% on mine)they also dont mind a little bit of wind.i put 2 aileron servos in as i found one HS55 was not enough to hold the ailerons.
