RCU Forums - View Single Post - Dynaflite SE5a Kit
Old 04-22-2005 | 08:49 AM
pgitta
Default RE: Dynaflite SE5a Kit
ORIGINAL: BobH
FYI the full scale has 5 degrees incidence and 5 degrees dihedral on the top and bottom wings and 5 degrees incidence on the stab.
Another way to measure your wing separation is to take a front view, measure the wing length vs separation and compare that to your plane. It will give you a ratio without involving the fuse. I say that because you may not know if your fuse is the proper size.
Bob, where did you happen to come across those figures? I did a quick search on the net and you would not believe the variations I came up with! upper 1, lower 0, tail 0 ,upper 3, lower 2, tail 1, tail 0, upper -1.5! blah blah blah.
