RE: truggy conversion
okay so i have an XTM XTERM buggy.
how would i change the gearing?
obviously i can change the CB. but changing that is not gonna relieve any pressure on the clutch system, is it? since the clutch still has to try to spin the CB in the first place.
do they have a different ring gear for the center diff?
or do i just use different diff oils to change the way the diffs react? if this is it what should be done? should i lighten the oil to releive tension or should i thicken it up to tighten the system?
