OK, but it's probably still too rich. They usually run at about 1.5 turns open on the high speed.
Have you used the running instruction at
www.ysperformance.com yet?
Also, an 18x8 may be a bit much on the 140L. Ideally the engine needs to run at 8000 to 8500 peak. You may just barely get there on the 18x8. Better to load the engine a bit lighter when breaking them in.
