RE: Multiplex Easy Star
Need your help.
My friend has one of the new Multiplex Easy Gliders. It is made of the same Elapor foam as the Easy Star and some other Mulitplex planes.
In any case, I was flying it and put it into a tree. I dinged the leading
edge of one wing. Nothing too serious. A depression about the depth of half a
nickel with a small crack in the foam, maybe 1/2 inch deep. Foam was starting to return to shape after sitting about 10 minutes but not all the way back yet.
To restore this foam to shape I heard you pour boiling water over the foam, or dip it in boiling water and the foam returns to its original shape. Is that so? Have you tried it? How much boiling water? How long does it take to happen?
I would presume after you do this you get it all aligned, drizzle in some CA
and it all glues together good as new.
Tell me this is so! Please!
