RCU Forums - View Single Post - Another twist question
Old 04-24-2005 | 10:39 PM
MemoryJack's Avatar
MemoryJack
Default RE: Another twist question
Kaoma
I have several flights on the twist now. It flies great !
You were right, the offset problem with the uneven elevator didn't cause a problem.
I also took your advice and turned down the the low rate throws even lower than the manual suggests.
It has been windy here lately, so I have not done any flying with high rates... I think it will be a handful.
I am also using the Evo .46 NT engine, because I already had one lying around. I'm not yet sure how well it is going to
work out. I may end up getting an O.S. .46 AX for it.
Thanks again for the advice !
