Model G260PU
Type 2 cycle piston valve type gasoline engine
Cooling System Air Cooled
Bore x Stroke (mm) 1-34 x 28
Displacement (cc) 25.4
Maximum Output Net ps (kw) 2.30 (1.69) Kilowatts (kW) ---> Horse power (hp): kW x 1.341 = hp 2.27
Gross ps (kw) 2.9 (2.13) kW x 1.341 = 2.86
Maximum Torque Net kg-m 0.16
Gross kg-m 0.21
Rotation Direction Counter-crockwise
(viewed from PTO shaft)
Fuel Pre-mixed Fuel, 25 (Gasoline) : 1 (High grade 2 cycle engine oil)
Lubrication Oil High-grade 2 cycle engine oil
Carburetor Diaphragm, butterfly valve type
Ignition CDI
Spark Plug RZ7C
Starter Flipping propeller or electric motor device
Overall Dimention Length (mm) 180
Width (mm) 193
Height (mm) 181
Dry Weight (kg) 1.69 (3.725 pound)
There is also a power / torque chart on the ZENOAH page..
http://www.zenoah.net
