G-26 QUESTION
Old 04-25-2005 | 01:31 PM
Default G-26 QUESTION
Hey Guys,
I have looked everywhere I can think of to come up with the horse power numbers on a G26 and cant find them must just be looking in all the wrong places. If anyone knows what the HP output of the G26 the info would be greatly app...Thanks
Old 04-25-2005 | 01:59 PM
RTK's Avatar
RTK
Default RE: G-26 QUESTION
Here is a graph with torque/HP
Old 04-25-2005 | 02:12 PM
bubbagates's Avatar
My Feedback: (32)
I am pretty sure it is in the Zenoah manual which is here:
http://www.horizonhobby.com/ProdInfo...nes-manual.pdf
If memory serves, it's something like 1.6 HP
I can tell you this. If you get one from Ralph Cunningham (RCIGN1) his are converted to electronic ignition are with a Mezjlik 18X6 prop they put out 17lbs of thrust and weight right around 48oz's AUW
His prices for a new coonverted G26 are around $400 shipped. Just shoot him an email or PM
Old 04-25-2005 | 03:00 PM
RTK's Avatar
RTK
bubbagates you are correct-
I have one of RCIGN1 (Ralph's) conversions and it will pull 17+lbs with a mezj 18x6 at 9000+
Best to prop for around 9000 rpm on the ground with un-restricted exhaust and best to use a mezj 18x6, most other I have tried fall short of 17+
Old 04-25-2005 | 05:58 PM
My Feedback: (18)
Model G260PU
Type 2 cycle piston valve type gasoline engine
Cooling System Air Cooled
Bore x Stroke (mm) 1-34 x 28
Displacement (cc) 25.4
Maximum Output Net ps (kw) 2.30 (1.69) Kilowatts (kW) ---> Horse power (hp): kW x 1.341 = hp 2.27
Gross ps (kw) 2.9 (2.13) kW x 1.341 = 2.86
Maximum Torque Net kg-m 0.16
Gross kg-m 0.21
Rotation Direction Counter-crockwise
(viewed from PTO shaft)
Fuel Pre-mixed Fuel, 25 (Gasoline) : 1 (High grade 2 cycle engine oil)
Lubrication Oil High-grade 2 cycle engine oil
Carburetor Diaphragm, butterfly valve type
Ignition CDI
Spark Plug RZ7C
Starter Flipping propeller or electric motor device
Overall Dimention Length (mm) 180
Width (mm) 193
Height (mm) 181
Dry Weight (kg) 1.69 (3.725 pound)
There is also a power / torque chart on the ZENOAH page.. http://www.zenoah.net
