First, when you get the kit, open the box and lay the top of the box next to the bottom.
From now on, ANYTIME you remove something from the box bottom, put it in the box top (With the exception of the manual and the part you are using of course)
Parts can get lost VERY quickly, and this habbit will assure that any part you're looking for is in one of only two places.
Next, Remove the manual and close the box. Spend at least a few hours reading the manual all the way through - this may be tought to do if you only have one bathroom in the house
Once you have read it through, do another read-through with the box in front of you. Inspect the parts as you go to make sure that you UNDERSTAND each step.
And finally, I'd be happy to supply directions for adding dual aileron servos, but it's been a LONG time since I built a 4* so refresh my memory a bit here... Am I correct in remembering that the 4* does NOT use cap strips on the ribs?
PS scrap sticks work well for mixing and applying epoxy too
