RCU Forums - View Single Post - Dual rate switch assignment???
Old 04-26-2005 | 05:57 PM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Dual rate switch assignment???
I have my 9C like Mike's. I use four switches while flying. One for each ELEV,RUD,AILE and the trainer switch for the spoilerons. I use the right hand three position switch for the throttle cut. Using the center as the cut and the high and low for the run position. Like Mike some tricks work better if one is on low and one on high. I mostly switch the AILE and ELEV so I put a piece of fuel tubing on those switches. It makes them easy to find.
David
