Pull Pull set up, whats yours look like
If you are using tiller arms it's important to have the servo arm exactly the same width as the rudder horns. If not one side will get loose or the system will bind. I use this system with a single servo set-up, with multiple servos I like a bearing bell crank, or wheel depending on the application.
