RCU Forums - View Single Post - CMPro 65" Extra 300s finished.. Pics!!
Old 04-27-2005 | 10:13 AM
freestyln's Avatar
freestyln
Default RE: CMPro 65" Extra 300s finished.. Pics!!
ha ha doesn't bother me mate, the 1.08 has plenty enough power mate.. not to mention the YS would make it alot more nose heavy that it already was with the OS.. The other night at like 2am i couldn't sleep so i attacked the back of my plane again and made a really neat hatch with the battery strapped to a support on the former near the elevator servo's so it helped alot with balancing, it only needed about 100gm's of weight in the tale after that. And as you mentioned if i took the Magnum 3" alluminium spinner off it would have balanced with out weight. But i like the look
Does anyone know if having the antenna come back on itself reduce range? I have the antenna running straight out the bottom after the wing mount bolts, to the tail with the normal set up of a rubber band and servo arm connected to it etc. but the antenna is fairly long on the JR R700... so it reaches the tail then back onitself aout 80mm.. is that a problem?
