RCU Forums - View Single Post - 28% Edge Balance With Brison 3.2 and Pull-Pull ??
Old 04-27-2005 | 10:52 AM
Cappy69
Default 28% Edge Balance With Brison 3.2 and Pull-Pull ??
Hi,
Just curious as to how this plane will balance and what may be needed to balance with this engine using a pull-pull setup. The reason I ask is that my engine is still about a week from my possesion but because of impatience I set up the rudder up pull-pull. I will be using 2 6v nimh packs also. Will placing these packs rearward in the hatch area be enough ballast to achieve balance or do you think I will still need to add some weight in the stab tube. Just trying to get an idea of what to expect when the time comes to mount the motor.
Cap
