RCU Forums - View Single Post - cen funfactor losing drive after 15 mins
Old 04-27-2005 | 03:43 PM
cenracer1
Default RE: cen funfactor losing drive after 15 mins
check as poor judgement said everything because at this point, you have a problem that is not easy to find... I would suggest you make sure when you put the clutch back together you make sure it is on the right way.. I had mine on backwards once and the engine revved very high before it would move.. then it finally stopped... Good luck and keep us posted..
