RCU Forums - View Single Post - 46AX break in
Old 04-27-2005 | 07:11 PM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: 46AX break in
ORIGINAL: OreoFilling62
how come my engine is running backwards? I started it and is going in the wrong direction and the prop is on right..... i tried switching the starter around and then it wont start. It is a bran new O.S 46
You're starting it by hand, or with a chicken stick, aren't you? This happens sometimes. Most of the times if you open the throttle up a bit and then close it, the engine will magically reverse itself. If this doesn't work, try some reverse psychology, flip it the opposite way. No, I'm not crazy (at least on this topic ), this really works.
