RCU Forums - View Single Post - Spinner moving on a BME 110
Old 04-28-2005 | 02:59 PM
bake
Default RE: Spinner moving on a BME 110
I have the same problem on my BME 110. The spinner back plate is screwed to the crankshaft (prop flange) with 4x40s and the prop drilled to fit over the screw heads so niether the backplate or prop can twist. But after a couple flights my spinner will rotate and rub on the prop. Guess I need locktite between the spinner and backplate?
