RCU Forums - View Single Post - Multiplex Magister RTF
Old 04-28-2005 | 07:26 PM
Greg Covey's Avatar
Greg Covey
Default Multiplex Magister RTF
Multiplex has recently introduced a revolutionary new R/C trainer molded from durable ELAPOR foam called the Magister. The Magister is an RTF (Ready to Fly) electric powered package with everything a beginner pilot needs to learn how fly. The airplane's electric engine can later be removed and a gas engine can be installed easily (assuming you become disgusted with your first electric flight experience). This makes the Magister one of the most advanced trainers available today.
The [link=http://www.multiplexusa.com/models/ParkFliers/Magister.htm]Magister[/link] is big, simple to fly, and, great for beginner or intermediate pilots. The plane is stable and solid in the air and slows down to a crawl for nice controlled landings. The Magister can handle moderate winds because of its size and weight.
Trainers have been around since the beginning of model flying. The so-called .40-sized trainer (with a 6.5cc glow motor) is offered in a multitude of variants all over the world. The beginner is expected to cope from the outset with an easily damaged all-wood model and a motor which is not properly set up and not even run-in. It’s no surprise that this type of “first model” is often the modeller’s last. At Multiplex they have adopted a different philosophy: a “ready-made model” moulded in robust, high-strength particle foam, fitted with a geared electric power system. The model is quickly made ready for flying, the motor starts when you just throw a switch, and the aircraft’s flying characteristics are simply outstanding. Success is all but guaranteed!
Specifications:[ul][*] Wingspan 64.2 in[*] Fuselage Length 46 in
[/ul]
Includes:[ul][*] Hitec Laser 4 Radio[*] Hitec HFS-04MG Receiver[*] Permax 680 Motor[*] APC 12x8 e-Propeller and 3:1 Gearbox[*] 3 Mini HD Servos[*] M32 Speed Control[*] 1900mAh Motor Battery[*] Multiplex 5008 DC NiCd/NiMH charger
[/ul]
Flying Weight:[ul][*] Weight Glow Powered 67 oz[*] Weight Electric 84 oz
[/ul]
Special features:[ul][*] Kit consisting of major parts moulded in ultra-robust ELAPOR particle foam[*] Steerable nosewheel[*] Damped main undercarriage (resists bouncing)[*] Wheels included in basic kit[*] Optional aero-tow coupling[*] Can be built as electric or glow-powered model (all parts* included in the kit)[*] Wings and tailplane removable for ease of transport. Two-part wing[*] Comprehensive decal sheet[*] Illustrated building instructions.
[/ul]
