RCU Forums - View Single Post - Tiger 2 ARF Problems
Old 04-28-2005 | 10:25 PM
cwrr5's Avatar
cwrr5
My Feedback: (32)
Default RE: Tiger 2 ARF Problems
ORIGINAL: Ernie Misner
The owner of the local hobby shop claims that the Tigers are similar in every way to the Sig 4* 40's. Has anyone owned both?
Ernie
In answer to your questions, sorta, and yes. They are both low wing, 40-60 size, second plane type planes, but the construction and overall setup is somewhat different. The 4* uses light ply frames, and stick type turtledeck, comes out of the kit as a taildragger, and has solid(unless you re-engineer ) tailfeathers. The tigger uses conventional ply/balsa fuse, has a slightly different shape to everything, the cross section is basically rectangular, and comes as a trike gear setup(also subject to re-engineering). Neither of mine have flown yet, but both are now on my workbench. 4*40 is about half done, the tigger was started about a year ago, but never finished due to time and travel to not so wonderful parts of the world. I have however flown both(other people's), and really like the performance of both, I think the 4* does better at slow speed, and the tiger 2 seemed to be "smoother", but that might just be me.
