RCU Forums - View Single Post - Checking aileron diferential
Old 04-28-2005 | 10:26 PM
flyboy91
Default RE: Checking aileron diferential
Juan,
When you check this you will want to point your airplane straight up to the sky and start to roll either way. If you need differential your airplane will cork screw and not roll axial. Do this in both directions and you should be good to go usually as it only takes about 3 or 4 degrees.
Andrew
