RCU Forums - View Single Post - Multiplex Magister RTF
Old 04-30-2005 | 08:32 AM
Greg Covey's Avatar
Greg Covey
Default RE: Multiplex Magister RTF
The tail assembles quickly since the only part glued in place is the vertical fin. The manual recommends using medium CA with some kicker. It says that white glue and epoxy are not effective on the ELAPOR particle foam.
The horizontal stabilizer simply screws in place and the linkage is hooked up with the supplied hex allen wrench.
Note that the antenna wire is routed along the fuselage belly in between the rubber band and held by tape at the tail.
ID:	264936   Click image for larger version
ID:	264937   Click image for larger version
