RCU Forums - View Single Post - Question for CEN or anyone
Old 04-30-2005 | 08:38 AM
taylormade
Default RE: Question for CEN or anyone
Thank you for the advice. What happens if the one way bearing in the pull start goes out? Will I then be stuck attempting to get a back plate? Since the pull start doesnt have to come out I assume you can use the starter box with the tiger drive on. I plan on using some type of rubber washer or o-ring between the screw and the plastic cover plate on the tiger drive to help keep from breaking. Thanks again!
