RCU Forums - View Single Post - SAME servo setup for IMAC and 3D??
Old 04-30-2005 | 11:23 AM
George E.'s Avatar
George E.
My Feedback: (16)
Default SAME servo setup for IMAC and 3D??
I fly mostly 3D and use a low rate for flying "IMAC" style, is this possible?? Lets say I have 50 degrees of travel on the elevator and the ATV is set at 125% when I switch to low rate and have only 10 degrees of elevator travel I'm only using 25% of the servos travel. Will I lose too much resolution this way? Also when the surfacse is set up for so much throw any servo back-lash is magnified.
So do you 3D on high and IMAC on low OR have a separate plane for each??
