Antenna Tube Question
Help........While building a Sig 1/5 scale Cub, I planned on running the antenna through a tube down the length of the fuse. I should have put a note to myself in the construction manual. I went merrily on my way and covered, doped, color coat and clear coat then came to the painful realization that I had neglected to install the antenna tube. Is it too late? I have slid the tube into the fuselage underneath the servos and it seems fairly secure (at least at the forward end) without any adhesive. My concern is the aft end of the tube. I'd rather not have it foul on the pull/pull lines. Should this be a concern or am I being overly cautious? Any words of wisdom from the RCU Gurus are more than welcome.
TIA
Mike
