RCU Forums - View Single Post - BME 102 Carb
Thread: BME 102 Carb
Old 05-01-2005 | 12:30 AM
Antique's Avatar
Antique
Default RE: BME 102 Carb
Wouldn't be much trouble to make a new insulator block from 3/8 G10...Bolt the block to the engine with flathead screws, rotate to carb to whatever angle you want and drill and tap the block for 10-32 allens....Piece of cake...every conversion I ever made has been done this way, the throttle shaft is parallel to the cylinder/s, direct straight connection to the throttle servo.
