RCU Forums - View Single Post - Antenna Tube Question
Old 05-01-2005 | 09:56 AM
the-plumber
Default RE: Antenna Tube Question
If you've built the J-3 scale at all, there will be access covers where the stab attaches to the fuse. Make those covers functional and of the correct size.
You should be able to 'fish around' in the fuse rear and capture the end of the antenna tube, and you can use a clean soda straw to 'inject' thin CA - just don't glue the antenna tube shut.
