RCU Forums - View Single Post - NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Old 05-01-2005 | 09:44 PM
  #39
nemesis4u's Avatar
nemesis4u
My Feedback: (77)
Default RE: NEMESIS4U's SHERMAN FULL FUNCTION BUILD
Then we attach the front drive sprocket and tracks and then adjust the track tension to where it only droops approx 25mm per the instruction manual...I have found this tension to be just right indoors or out..at least for me...
After this I applied the road wheel caps and then installed the speaker box, battery, harnesses and all the internal stuffings per instruction manual and did not deviate...went along very well so I will not bore you to death with that...
ID:	265661   Click image for larger version
