RCU Forums - View Single Post - Help With First 3d Foamie
Old 05-02-2005 | 12:16 PM
EVOL's Avatar
EVOL
Default RE: Help With First 3d Foamie
********EMERGENCY***************
i just went to my hobby store to pick up some battry connectors and i was told some bad news that im not sure is correct.
they were saying that the BP 21 draws a max 13 amps and that the battery i have (electrifly 3C 350) would be toast if i go full power. so i asked them what kind of battery i COULD use and the only thing they had was this big HEAVY 1050 mha battery for $60. this battery weighed about 1/2 of what the entire plane did.
so.........i have a 20 amp speed control so what battery are you guys using with your BP 21 brushless? i understand that i could also prop the engine so that is wount be able to draw 13 amps so what prop should i use? HEEEEEELP
EVOL
