RCU Forums - View Single Post - Something extra build question
Old 05-03-2005 | 12:14 PM
hookedonrc's Avatar
hookedonrc
Default RE: Something extra build question
One other thing you can do if you don't want to leave the carboard tube unglued. Open up the back side of the tank shelf by using a dremel or similar tool to make the arc on the shelf a little wider and deeper. I did mine that way the tank will drop down just as the back end of the tank reaches the cardboard tube. I had to do that with mine because I had already glued the cardboard tube in place when I thought about it
