RE: Engine for Top Flite Arrow
The arrow is about the same size and weight as the Bonanza from Top Flight. A Saito 100 flies that model very well. I have the RCV 90 in a P-26. Remember that the RCV is geared so it operates at about half the RPM of the Saito. You will need to turn a larger diameter and pitch prop. Ground clearance may be a problem.
