RE: I don't think I'm going to be happy here,,,
updated,,,,
OK my carb is at Morris Hobbies, because it will not pump,,,
so the guy here at the chain-saw shop gave me a couple carbs to try (JUST to see if I can get them to pump,,, NOT to start the motor)
the first carb would not pump,,
the 2nd carb~ (this carb dos NOT have a choke) this carb would pump only if I choked it with my thumb, ""this carb filled a clean/dry 20 inch long clear fuel line in about 7 or 8 flips of the prop""
my question is, choking should not have anything to do with the pump, or should it ??
Jim
