RE: updated ,,,
Yes it does matter. It even matters so much, that there is a world of difference.
You must get the carb wet or it will not pump at all because the dry valves do not work. That is why garden appliances have the bulb primer fitted. This draws fuel into the carb, and discharges it back to the tank. Once the carb is full of fresh fuel, all is OK, or should be.
