RCU Forums - View Single Post - Collari .30
Thread: Collari .30
Old 05-03-2005 | 05:58 PM
PeteOz
Default RE: Collari .30
ORIGINAL: R/C Modelsport
ORIGINAL: fmawyer
Guys got one the other day (collari 30) that has the new rotor start. Problem is I cant get a header to go on it cause it wont clear the rotor start . Any suggestions..............
You need this. But you could also grind away your existing header.
Isn't that header set up for rear exhaust? It goes 180 degree, back onto itself, while most MT exhaust goes out the side, needing basically a 90 Degree bend
