RE: Engine Probs
Your low end adjustment is in the center of the throttle control arm. If you look in there you will see a SMALL slot. That is the end of the low end needle.
FWIW - Seal the backplate and the carb o-ring with some silicone. Tower 46 engines are well known for air leaks at those 2 locations.
