RCU Forums - View Single Post - Ryobi 31 cc Conversion
Old 05-03-2005 | 07:02 PM
cal.45acp
Default RE: Ryobi 31 cc Conversion
If you have a tapered seat cylinder head you should use a tapered plug, why, because the tapered plug is part of the cooling process just as the cylinder fins are; you can probably get away with a gasket type plug,unless you are reaching critical head temps. The taper is meant to be a close fit , not just for sealing , but for the ability to absorb heat from the head to the plug body(the metal part)
