RE: THRUST WASHER PULLER
I don't know if you guys are catching on here or not but the drive washer on a OS 50SX will just slide off with your fingers. There is no tapered collet or anything on it.
But you better get the woodruff key out or the crank will not slide out of the front bearing. Sometimes the key falls out and sometimes it takes pliers.
Enjoy,
Jim
