RCU Forums - View Single Post - Optic 6 Programming Lockup
Old 05-04-2005 | 10:27 AM
CFIMEI
Default Optic 6 Programming Lockup
Hi,
With Optic 6 I was using PMX1 to couple elevator to an aileron channel 1. After passing through several master/slave combinations the Tx totally locked up & had to be shut down/repowered to continue further programming. My Eclipse also occasionally does this. Should I assume that this is "just the way it is" or do you think the Optic lockup is a symptom of something abnormal?
CFIMEI
