RCU Forums - View Single Post - NERF Demo
Thread: NERF Demo
Old 10-07-2002 | 12:13 PM
Cajun
Default NERF Demo
Jimbo, what prop are you going to use? I've been trying to find low pitch 10" props and they are not available, except for APC. I've tried the 10x4s, and with a light airframe, and most 25s, the speed will approach what we are flying now.
A thick wing might help, but will not slow it down enough to fall into the 40-45 MPH area. A 10x4 prop turning 15K has a speed potential of about 60MPH. My Flippin Disk, with a thick foam airfoil and 3 pounds with a GMS .25 and 10X4 MA prop will probably approach 50/55 MPH, in level flight, possibly more.
I hope you find the right combination, but history has proven in Pylon and Combat, if an engine/prop has the potential to achieve a given top speed, some dudes will be fudging enough to reach this speed. This puts a big burden on the CD to attempt to enforce what is mandated for equipment.
I have no doubts it is possible, but Probable,Hmmmm
This is what happened to Open B. The founders never envisioned the possibility of someone flying a 2.5 lb plane with a Jett .30 engine at 100 MPH. But it happened and it was legal by the rules.
Good Luck.
Cajun
