RE: S3004 Throws
Hi Vince,
Your servo will see an average of 60 degrees of movement as is normal with most all servos. This is 60 degrees total movement. 30 degrees each way from center.
To realize more throw, you will want to use the longest servo arms that you can, and position the control surface as far out on the arm as possible.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
