RCU Forums - View Single Post - heating problems
Old 05-06-2005 | 07:59 PM
Gremlin Castle
My Feedback: (14)
Default RE: heating problems
The bottom half of the two stroke motor runs pretty cool while the fuel and air are being sucked thru. The heat transfer there happens after the motor has shut down. running toward the rich side helps rather than tweaking it to the max prior to takeoff. sometimes a scoop that picks up undisturbed air and directs it straight to the cylinder head will do the trick. Usually a heat sink cylinder head is the most reliable.
If you want to go wild you might try making a venturi cooling system using the exhaust gas flow to suck cooling air past the cylinder like the old Aerocommander 720s had. It was the only plane that I ever flew in where you increased the engine rpm while standing still to improve the cooling flow thru the cowling.
ORIGINAL: kingwoodbarney
Well, I think the darn thing just flys to slowly to provide adequate airflow.. its like it is always taxiing.
Alluminum motor mounts would help draw some heat from the case. And then you could have sheet brass or alluminum bolted in between the engine and mount to increase the area even more.
There are fuels with more oil, that might help some. The answer will most likely come form the shotgun approach. try everything !!
Run it as rich as you can, for sure.
